Ir para o conteúdo principal
Motion Computing LE1600 Battery Replacement
  1. Motion Computing LE1600 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device so the screen is facing down.
    Pergunte ao FixBot
    Comentar
  2. Motion Computing LE1600 Battery Replacement: passo 2, imagem 1 %32 Motion Computing LE1600 Battery Replacement: passo 2, imagem 2 %32
    • Slide the battery lock switch next to the power slider to the unlocked position.
    Pergunte ao FixBot
    Comentar
  3. Motion Computing LE1600 Battery Replacement: passo 3, imagem 1 %32 Motion Computing LE1600 Battery Replacement: passo 3, imagem 2 %32 Motion Computing LE1600 Battery Replacement: passo 3, imagem 3 %32
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
    Pergunte ao FixBot
    Comentar
Conclusão
David Troy
Membro desde: 04/04/12
44 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-14, Forte Spring 2012 Membro de Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Membros
Autoria de 5 guias
1Comentário do guia
Wow that’s so cool thanks bro
Leon Byrne - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 3,184
