Ir para o conteúdo principal
Motherboard Replacement
O que você precisa
  1. Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32 Motherboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Motherboard Replacement: passo 2, imagem 1 %32
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Remove masking tape from the battery.
  4. Motherboard Replacement: passo 4, imagem 1 %32 Motherboard Replacement: passo 4, imagem 2 %32 Motherboard Replacement: passo 4, imagem 3 %32
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Motherboard Replacement: passo 5, imagem 1 %32 Motherboard Replacement: passo 5, imagem 2 %32 Motherboard Replacement: passo 5, imagem 3 %32
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Como soldar e dessoldar contatos
    • Use caution when operating the soldering iron.
  6. Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Motherboard Replacement: passo 7, imagem 1 %32
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Motherboard Replacement: passo 8, imagem 1 %32 Motherboard Replacement: passo 8, imagem 2 %32 Motherboard Replacement: passo 8, imagem 3 %32
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
Conclusão
Uma outra pessoa concluiu este guia.
Connor Fisher
Membro desde: 11/04/16
212 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 4-1, Williams Fall 2016 Membro de Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 276
