O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn over the device.
Peel the silicone feet up to remove.
Remove all eight of the 11 mm Phillips screws from the bottom of the device.
Remove the bottom panel speaker using an iFixit opening tool.
Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
Remove the plastic panel.
Remove the battery from the holder. It may be difficult the first time.
Remove the pressure-fitted foam from the slot by hand.
Unravel and remove foam from the wires.
Using a soldering iron, remove the leads, separating the battery from motherboard.
Remove the three screws that are holding the speaker down.
Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
Remove the speaker from the motherboard.
Remove the speaker ring.
Repeat Steps 5-7 with the other speaker.
Remove these two 4.5 mm Philips silver screws holding down the motherboard.
The motherboard should be able to be lifted right out of the housing.
Using a spudger or plastic opening tool, lift flap on the ribbon cable ZIF connector.
Using a plastic pry tool or fine tip plastic tool to open the clamp.
Using the tool, try lifting the clamp up on either location, noted by the blue arrow.
The ribbon should pop out, if not you should be able to slide it out from the clamp.
