Introdução
If your mouse is intermittently disconnecting, randomly missing movements and inputs - you might have a broken or damaged mouse cable. The mouse cable carries data from the mouse to your computer. A damaged cable can result in missed mouse movements and inputs. Before starting this guide try a different connector (most likely USB) port on your computer, and inspect the connector for dirt and debris.
This guide shows an easy, step-by-step process on how to replace the mouse cable in a Glorious Model O- mouse.
The mouse should be physically unplugged from your computer prior to beginning your repair.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
Turn the mouse over so that the feet are facing you.
Remove the bottom two mouse feet using tweezers.
Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
Route the new cable through the slit in the circuit board.
Route the new cable behind the pillars.
Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
3 outras pessoas executaram este guia.
It helps if you warm the two feet a little before you pull them off. You can use a hair-dryer or maybe a toaster if you are careful
Kampi-Akseli - Responder
