Ir para o conteúdo principal
Model O- Mouse Cable Replacement
O que você precisa
  1. Model O- Mouse Cable Replacement, Mouse Cable: passo 1, imagem 1 %32 Model O- Mouse Cable Replacement, Mouse Cable: passo 1, imagem 2 %32 Model O- Mouse Cable Replacement, Mouse Cable: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
  2. Model O- Mouse Cable Replacement: passo 2, imagem 1 %32 Model O- Mouse Cable Replacement: passo 2, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
  3. Model O- Mouse Cable Replacement: passo 3, imagem 1 %32 Model O- Mouse Cable Replacement: passo 3, imagem 2 %32 Model O- Mouse Cable Replacement: passo 3, imagem 3 %32
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
  4. Model O- Mouse Cable Replacement: passo 4, imagem 1 %32 Model O- Mouse Cable Replacement: passo 4, imagem 2 %32
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
  5. Model O- Mouse Cable Replacement: passo 5, imagem 1 %32 Model O- Mouse Cable Replacement: passo 5, imagem 2 %32
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
  6. Model O- Mouse Cable Replacement: passo 6, imagem 1 %32 Model O- Mouse Cable Replacement: passo 6, imagem 2 %32
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
  7. Model O- Mouse Cable Replacement: passo 7, imagem 1 %32 Model O- Mouse Cable Replacement: passo 7, imagem 2 %32
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
  8. Model O- Mouse Cable Replacement: passo 8, imagem 1 %32
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
  9. Model O- Mouse Cable Replacement: passo 9, imagem 1 %32 Model O- Mouse Cable Replacement: passo 9, imagem 2 %32
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
Linha de Chegada
3 outras pessoas executaram este guia.
Theo SW
Membro desde: 01/22/21
241 Reputação
Autoria de 1 guia
2 comentários
Where can I get the replacement cable for it?
Ekke Sten - Responder
does glorius them selfs sell replacment parts ?
aniss-97 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 86
Duração total: 12,436
