Ir para o conteúdo principal
Modal MD-WORCSS6 Battery Replacement
O que você precisa
  1. Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: passo 1, imagem 1 %32 Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: passo 1, imagem 2 %32
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
    Pergunte ao FixBot
    Comentar
  2. Modal MD-WORCSS6 Battery Replacement: passo 2, imagem 1 %32 Modal MD-WORCSS6 Battery Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
    Pergunte ao FixBot
    Comentar
  3. Modal MD-WORCSS6 Battery Replacement: passo 3, imagem 1 %32 Modal MD-WORCSS6 Battery Replacement: passo 3, imagem 2 %32
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
    Pergunte ao FixBot
    Comentar
  4. Modal MD-WORCSS6 Battery Replacement: passo 4, imagem 1 %32 Modal MD-WORCSS6 Battery Replacement: passo 4, imagem 2 %32 Modal MD-WORCSS6 Battery Replacement: passo 4, imagem 3 %32
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
    Pergunte ao FixBot
    Comentar
  5. Modal MD-WORCSS6 Battery Replacement: passo 5, imagem 1 %32 Modal MD-WORCSS6 Battery Replacement: passo 5, imagem 2 %32 Modal MD-WORCSS6 Battery Replacement: passo 5, imagem 3 %32
    • Carefully peel the tape off far enough to remove the 3 batteries.
    Pergunte ao FixBot
    Comentar
  6. Modal MD-WORCSS6 Battery Replacement, Battery: passo 6, imagem 1 %32
    • Replace the batteries by pulling them out of their holder and putting new ones in the same places.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
1Comentário do guia
Where do you get the replacement batteries?
Gerry David - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 46
Ao todo: 1,634
