Ir para o conteúdo principal
Mirror Box Removal
O que você precisa
  1. Mirror Box Removal, Remove film door: passo 1, imagem 1 %32
    • Push down the latch to release the film door.
    Pergunte ao FixBot
    Comentar
  2. Mirror Box Removal, Remove top cover screws: passo 2, imagem 1 %32 Mirror Box Removal, Remove top cover screws: passo 2, imagem 2 %32 Mirror Box Removal, Remove top cover screws: passo 2, imagem 3 %32
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
    Pergunte ao FixBot
    Comentar
  3. Mirror Box Removal, Remove top cover screws: passo 3, imagem 1 %32 Mirror Box Removal, Remove top cover screws: passo 3, imagem 2 %32 Mirror Box Removal, Remove top cover screws: passo 3, imagem 3 %32
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
    Pergunte ao FixBot
    Comentar
  4. Mirror Box Removal, Lift top cover: passo 4, imagem 1 %32
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
    Pergunte ao FixBot
    Comentar
  5. Mirror Box Removal, Access flash connections: passo 5, imagem 1 %32 Mirror Box Removal, Access flash connections: passo 5, imagem 2 %32
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
    Pergunte ao FixBot
    Comentar
  6. Mirror Box Removal, Discharge flash capacitors: passo 6, imagem 1 %32
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    Pergunte ao FixBot
    Comentar
  7. Mirror Box Removal, Disconnect right flex cable: passo 7, imagem 1 %32
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    Pergunte ao FixBot
    Comentar
  8. Mirror Box Removal, Disconnect left flex cable: passo 8, imagem 1 %32
    • Desolder the red wire.
    Pergunte ao FixBot
    Comentar
  9. Mirror Box Removal, Desolder flash connections: passo 9, imagem 1 %32 Mirror Box Removal, Desolder flash connections: passo 9, imagem 2 %32
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
    Pergunte ao FixBot
    Comentar
  10. Mirror Box Removal, Desolder the flash flex cable: passo 10, imagem 1 %32 Mirror Box Removal, Desolder the flash flex cable: passo 10, imagem 2 %32
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
    Pergunte ao FixBot
    Comentar
  11. Mirror Box Removal, Remove bottom cover: passo 11, imagem 1 %32 Mirror Box Removal, Remove bottom cover: passo 11, imagem 2 %32 Mirror Box Removal, Remove bottom cover: passo 11, imagem 3 %32
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
    • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    Pergunte ao FixBot
    Comentar
  12. Mirror Box Removal, Remove front left cover: passo 12, imagem 1 %32
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
    Pergunte ao FixBot
    Comentar
  13. Mirror Box Removal, Remove front cover: passo 13, imagem 1 %32
    • Remove front cover.
    Pergunte ao FixBot
    Comentar
  14. Mirror Box Removal, Unscrew front right cover: passo 14, imagem 1 %32 Mirror Box Removal, Unscrew front right cover: passo 14, imagem 2 %32 Mirror Box Removal, Unscrew front right cover: passo 14, imagem 3 %32
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
    Pergunte ao FixBot
    Comentar
  15. Mirror Box Removal, Remove the front right cover: passo 15, imagem 1 %32
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
    Pergunte ao FixBot
    Comentar
  16. Mirror Box Removal, Remove bottom plate: passo 16, imagem 1 %32 Mirror Box Removal, Remove bottom plate: passo 16, imagem 2 %32 Mirror Box Removal, Remove bottom plate: passo 16, imagem 3 %32
    • Remove the protective mask around the accessory grip contacts.
    • Lift the flex contacts free of their retaining posts. Use isopropyl alcohol to soften any glue or tape that is present.
    • Remove four 4.0 mm #00 screws (standard metric threads).
    • Remove four 4.0 mm #00 screws (plastic threads).
    Pergunte ao FixBot
    Comentar
  17. Mirror Box Removal, Desolder speaker: passo 17, imagem 1 %32
    • Desolder the black and red wires for the speaker.
    Pergunte ao FixBot
    Comentar
  18. Mirror Box Removal, Desolder connections to bottom flex circuit: passo 18, imagem 1 %32 Mirror Box Removal, Desolder connections to bottom flex circuit: passo 18, imagem 2 %32 Mirror Box Removal, Desolder connections to bottom flex circuit: passo 18, imagem 3 %32
    • Desolder the white and pink wires.
    • Desolder the red, black and gray wires.
    • Desolder the red, black and orange wires.
    • Desolder the white and blue wires.
    • Carefully peal the tape away and detach the red, black, white and blue wires from the glue. Use isopropyl alcohol to soften the glue if necessary.
    • Desolder the flex connection.
    Pergunte ao FixBot
    Comentar
  19. Mirror Box Removal, Desolder connections to top flex circuit: passo 19, imagem 1 %32 Mirror Box Removal, Desolder connections to top flex circuit: passo 19, imagem 2 %32 Mirror Box Removal, Desolder connections to top flex circuit: passo 19, imagem 3 %32
    • Desolder red, black, gray and orange wires.
    • Desolder flex contacts.
    • Disconnect flex connector.
    • Desolder yellow and purple wires.
    Pergunte ao FixBot
    Comentar
  20. Mirror Box Removal, Desolder connections to top flex circuit: passo 20, imagem 1 %32 Mirror Box Removal, Desolder connections to top flex circuit: passo 20, imagem 2 %32
    • Desolder black wire.
    • Desolder battery contact tab.
    Pergunte ao FixBot
    Comentar
  21. Mirror Box Removal, Desolder flex connection above the lens mount: passo 21, imagem 1 %32 Mirror Box Removal, Desolder flex connection above the lens mount: passo 21, imagem 2 %32
    • Desolder flex connection and remove from retention posts. Use isopropyl alcohol to soften the glue if necessary.
    • Carefully peal the flex cable from the surface of the flash capacitor. Use isopropyl alcohol to soften the glue if necessary.
    Pergunte ao FixBot
    Comentar
  22. Mirror Box Removal, Remove eye piece assembly: passo 22, imagem 1 %32 Mirror Box Removal, Remove eye piece assembly: passo 22, imagem 2 %32
    • Remove two 5.0 mm #00 screws.
    • Remove the eye piece.
    • The outer cover of the eye piece is only attached with double sided tape and may come away on its own. Make sure the entire eye piece unit is removed before proceeding.
    Pergunte ao FixBot
    Comentar
  23. Mirror Box Removal, Remove lens release switch: passo 23, imagem 1 %32 Mirror Box Removal, Remove lens release switch: passo 23, imagem 2 %32
    • Remove one #00 screw.
    • Reassembly Note: Ensure that the lower contact catches on the plastic nub and that the contact is open when the lens release button is not pressed.
    Pergunte ao FixBot
    Comentar
  24. Mirror Box Removal, Flip the mirror up: passo 24, imagem 1 %32 Mirror Box Removal, Flip the mirror up: passo 24, imagem 2 %32
    • Rotate the black gear downward until the mirror flips up into the taking position. It may take several turns.
    • Some failures will result in the mirror appearing to be in the upper position but the internal mechanism is still "down". The mechanism needs to be moved to release the mirror box.
    Pergunte ao FixBot
    Comentar
  25. Mirror Box Removal, Detach flex circuit: passo 25, imagem 1 %32 Mirror Box Removal, Detach flex circuit: passo 25, imagem 2 %32
    • Remove one 4.0 mm screw.
    • Gently lift the flex circuit away from the housing.
    Pergunte ao FixBot
    Comentar
  26. Mirror Box Removal, Unscrew the mirror box: passo 26, imagem 1 %32 Mirror Box Removal, Unscrew the mirror box: passo 26, imagem 2 %32
    • Remove two 6.5 mm #0 screws.
    • Remove one 8.0 mm #0 screw.
    • Remove one 4.5 mm #00 screw.
    • Remove two 2.5 mm #00 screws.
    • There may be a shim washer here. Remove if loose.
    • Remove one 4.0 mm #00 shoulder screw.
    Pergunte ao FixBot
    Comentar
  27. Mirror Box Removal, Remove the mirror box: passo 27, imagem 1 %32 Mirror Box Removal, Remove the mirror box: passo 27, imagem 2 %32
    • Push the mirror box up to free it from the bottom plate.
    • Lift the left side of the mirror box and rotate it up and out of the camera body.
    • Be gentle. Keep an eye out for any snagged flex cables or wires. The right side of the mirror box is still connected to the camera body and it cannot be completely removed.
    • Check for shim washers at the mount locations. Note location and remove if loose.
    Pergunte ao FixBot
    Comentar
Conclusão
Sam Gustafson
Membro desde: 09/01/22
11.540 Reputação
Autoria de 78 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 42
Ao todo: 670
