Ir para o conteúdo principal
Minolta Dimage Xt Capture Button Replacement
O que você precisa
    1. Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, imagem 1 %32 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, imagem 2 %32 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, imagem 3 %32
      • Locate and remove the silver screws on each side of the camera.
      • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
      Pergunte ao FixBot
      Comentar
    2. Minolta Dimage Xt Capture Button Replacement: passo 2, imagem 1 %32 Minolta Dimage Xt Capture Button Replacement: passo 2, imagem 2 %32 Minolta Dimage Xt Capture Button Replacement: passo 2, imagem 3 %32
      • Then, carefully pry apart the front and back outer casing away from the internal components.
      • Be aware of the ribbon wire that will disconnect when the casing is detached.
      Pergunte ao FixBot
      Comentar
    1. Minolta Dimage Xt Capture Button Replacement, Capture Button: passo 3, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Choosing the front half of the casing, locate the capture button on the top.
      • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
      Pergunte ao FixBot
      Comentar
    2. Minolta Dimage Xt Capture Button Replacement: passo 4, imagem 1 %32
      • The button will spring free. The capture device consists of the plastic button and a small metal spring.
      • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
      Pergunte ao FixBot
      Comentar
Conclusão
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Membro desde: 03/11/13
56 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 12-4, Benson Spring 2013 Membro de Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 972
