Ir para o conteúdo principal
Milwaukee M18 2606-20 Circuit Board Replacement
O que você precisa
  1. Milwaukee M18 2606-20 Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 Milwaukee M18 2606-20 Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
    • Remove the two 21 mm screws, using the T3 Torx Screwdriver, from the top of the case.
  2. Milwaukee M18 2606-20 Circuit Board Replacement: passo 2, imagem 1 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 2, imagem 2 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 2, imagem 3 %32
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
  3. Milwaukee M18 2606-20 Circuit Board Replacement: passo 3, imagem 1 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 3, imagem 2 %32
    • Peel back the sticker at the bottom of the drill handle.
  4. Milwaukee M18 2606-20 Circuit Board Replacement: passo 4, imagem 1 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 4, imagem 2 %32
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  5. Milwaukee M18 2606-20 Circuit Board Replacement: passo 5, imagem 1 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 5, imagem 2 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the 4-pin and 5-pin connector, using the tweezers, from the circuit board.
  6. Milwaukee M18 2606-20 Circuit Board Replacement: passo 6, imagem 1 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 6, imagem 2 %32 Milwaukee M18 2606-20 Circuit Board Replacement: passo 6, imagem 3 %32
    • Desolder all of the wires connected to the circuit board.
    • When you take the circuitboard out of the case, watch for a spring that is in the back of the battery contacts as it can fly out.
Conclusão
Um comentário
Replacement M18 Battery for Milwaukee Power Tool 2606-20
Type: Li-ion
Volt: 18V
Capacity: 5000mAh
Color: Black
Weight: 932g
Dimension: 141.15 x 78.00 x 73.95mm
Milwaukee 2606-20 Power Tool Batteries are made from the highest quality parts and are compatible with the Milwaukee cordless tools. And, this Milwaukee 2606-20 battery can be charged with original battery charger. Go to view more about this battery on https://www.drill-batteries.com/batteryp...
Drillbatterycomau - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 118
Duração total: 9,147
