Ir para o conteúdo principal
Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement
O que você precisa
    1. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Outer Casing: passo 1, imagem 1 %32
      • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: passo 2, imagem 1 %32
      • Remove metal clip located at the base of the drill, where the battery is to be inserted.
      • You may need to use a spudger if the clip is too difficult to remove with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: passo 3, imagem 1 %32 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: passo 3, imagem 2 %32 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: passo 3, imagem 3 %32
      • Use both hands to lift and remove the gear case assembly from the shell casing.
      • Set the gear case assembly aside.
      Pergunte ao FixBot
      Comentar
    2. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: passo 4, imagem 1 %32
      • While holding the shell in one hand, pull the end of the broken forward/reverse shuttle out of the casing.
      • Set the broken forward/reverse shuttle aside.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 2,421
