Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2753-20 Trigger Replacement
O que você precisa
  1. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: passo 1, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: passo 1, imagem 2 %32
    • While pinching the red locking buttons, pull the battery away from the front of the drill until the battery is fully removed.
    • The battery is missing from this device so its removal is being mimed.
  2. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: passo 2, imagem 1 %32
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  3. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: passo 3, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: passo 3, imagem 2 %32
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  4. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: passo 4, imagem 1 %32 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: passo 4, imagem 2 %32
    • Lift the trigger assembly from the device. It is connected to the circuit board by wires.
    • Carefully desolder the wires off of the trigger assembly using a soldering iron on medium heat.
    • Refer to this guide for proper desoldering technique.
  5. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: passo 5, imagem 1 %32
    • Remove the trigger assembly from the device.
    • Replace old trigger assembly with replacement part no. 14-20-0013.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 47
Duração total: 4,526
