Ir para o conteúdo principal
Milwaukee Hex Impact Driver 2656-20 Case Disassembly
O que você precisa
    1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: passo 1, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: passo 1, imagem 2 %32
      • Squeeze the red buttons on the battery.
      • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
      Pergunte ao FixBot
      Comentar
    1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, imagem 1 %32 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: passo 2, imagem 2 %32
      • Lay the impact driver on its side.
      • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
      • Separate the two halves by pulling up on the top half.
      • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
      • Lay the top half to the side.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 59
Ao todo: 3,096
