Ir para o conteúdo principal
Milwaukee Hackzall 2625-20 Trigger Replacement
O que você precisa
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: passo 1, imagem 1 %32 Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: passo 1, imagem 2 %32
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: passo 2, imagem 1 %32
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: passo 3, imagem 1 %32 Milwaukee Hackzall 2625-20 Trigger Replacement: passo 3, imagem 2 %32
    • Remove the rest of the trigger assembly from the case.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 1,749
