Ir para o conteúdo principal
Milwaukee Hackzall 2625-20 Terminal Block Replacement
O que você precisa
  1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: passo 1, imagem 1 %32 Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: passo 1, imagem 2 %32
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Terminal Block: passo 2, imagem 1 %32
    • Carefully remove the terminal block from the casing and note that there is a spring set into it.
  3. Milwaukee Hackzall 2625-20 Terminal Block Replacement: passo 3, imagem 1 %32 Milwaukee Hackzall 2625-20 Terminal Block Replacement: passo 3, imagem 2 %32
    • Use a soldering iron to melt any existing soldered attachments.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,485
