Ir para o conteúdo principal
Milwaukee Hackzall 2625-20 Motor Replacement
O que você precisa
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: passo 1, imagem 1 %32 Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: passo 1, imagem 2 %32
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: passo 2, imagem 1 %32
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: passo 3, imagem 1 %32 Milwaukee Hackzall 2625-20 Motor Replacement: passo 3, imagem 2 %32
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
Conclusão
2 comentários
Is there any chance to change only brushes in this motor?
Marcin Kędzior - Responder
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 40
Duração total: 2,419
