Ir para o conteúdo principal
Mill Cutter Paper Stripper Replacement
O que você precisa
    1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: passo 1, imagem 1 %32
      • Unplug the shredder from the wall electrical outlet.
      • Remove the shredder from its catch basket and place it face down on a flat surface.
      Pergunte ao FixBot
      Comentar
    2. Mill Cutter Paper Stripper Replacement: passo 2, imagem 1 %32 Mill Cutter Paper Stripper Replacement: passo 2, imagem 2 %32 Mill Cutter Paper Stripper Replacement: passo 2, imagem 3 %32
      • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
      • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
      Pergunte ao FixBot
      Comentar
    3. Mill Cutter Paper Stripper Replacement: passo 3, imagem 1 %32 Mill Cutter Paper Stripper Replacement: passo 3, imagem 2 %32
      • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
      Pergunte ao FixBot
      Comentar
    4. Mill Cutter Paper Stripper Replacement: passo 4, imagem 1 %32 Mill Cutter Paper Stripper Replacement: passo 4, imagem 2 %32
      • Once all of the screws have been removed, pull the casing apart.
      • Remove the stripper guide from the housing unit.
      • Use caution to prevent the trigger guard from falling apart.
      Pergunte ao FixBot
      Comentar
    5. Mill Cutter Paper Stripper Replacement: passo 5, imagem 1 %32 Mill Cutter Paper Stripper Replacement: passo 5, imagem 2 %32 Mill Cutter Paper Stripper Replacement: passo 5, imagem 3 %32
      • Remove the e-clips from the gears on the left side with a flathead screwdriver.
      • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
      Pergunte ao FixBot
      Comentar
    6. Mill Cutter Paper Stripper Replacement: passo 6, imagem 1 %32 Mill Cutter Paper Stripper Replacement: passo 6, imagem 2 %32 Mill Cutter Paper Stripper Replacement: passo 6, imagem 3 %32
      • Remove the gears from both sides.
      • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
      • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
      Pergunte ao FixBot
      Comentar
    7. Mill Cutter Paper Stripper Replacement: passo 7, imagem 1 %32 Mill Cutter Paper Stripper Replacement: passo 7, imagem 2 %32
      • Replace the mill cutter paper stripper set and stripper guide set.
      • Use protective gloves as the blades are very sharp.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 2,002
