Ir para o conteúdo principal
Midiman Oxygen 8 Power Port Replacement
O que você precisa
  1. Midiman Oxygen 8 Power Port Replacement, Midiman Oxygen 8 Backplate Disassembly: passo 1, imagem 1 %32 Midiman Oxygen 8 Power Port Replacement, Midiman Oxygen 8 Backplate Disassembly: passo 1, imagem 2 %32
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
    Pergunte ao FixBot
    Comentar
  2. Midiman Oxygen 8 Power Port Replacement: passo 2, imagem 1 %32 Midiman Oxygen 8 Power Port Replacement: passo 2, imagem 2 %32
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
    Pergunte ao FixBot
    Comentar
  3. Midiman Oxygen 8 Power Port Replacement: passo 3, imagem 1 %32 Midiman Oxygen 8 Power Port Replacement: passo 3, imagem 2 %32 Midiman Oxygen 8 Power Port Replacement: passo 3, imagem 3 %32
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
    Pergunte ao FixBot
    Comentar
  4. Midiman Oxygen 8 Power Port Replacement: passo 4, imagem 1 %32 Midiman Oxygen 8 Power Port Replacement: passo 4, imagem 2 %32
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
    Pergunte ao FixBot
    Comentar
  5. Midiman Oxygen 8 Power Port Replacement, Power Port: passo 5, imagem 1 %32
    • The power plug port in soldered onto the motherboard, and screwed onto the back plate.
    Pergunte ao FixBot
    Comentar
  6. Midiman Oxygen 8 Power Port Replacement: passo 6, imagem 1 %32
    • The battery power cord must be detached and removed from the motherboard prior to it being unsecured from the back plate.
    • Using the point tip of the black spudger tool, press into the gap between the plug and retaining clip in the socket, then gently pull on the plug wires to remove it from the socket.
    Pergunte ao FixBot
    Comentar
  7. Midiman Oxygen 8 Power Port Replacement: passo 7, imagem 1 %32 Midiman Oxygen 8 Power Port Replacement: passo 7, imagem 2 %32
    • There are 4 M1.5 x 3 screws that must be removed to separate the motherboard from the back plate.
    Pergunte ao FixBot
    Comentar
  8. Midiman Oxygen 8 Power Port Replacement: passo 8, imagem 1 %32
    • There are 3 solder points that connect the power socket to the motherboard, 2 electrical and 1 to secure the housing.
    • De-Solder the three connections to remove the old power port.
    • Solder on the new power port to complete the replacement.
    Pergunte ao FixBot
    Comentar
Conclusão
Scott Miller
Membro desde: 10/04/16
437 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-6, Sullivan Fall 2016 Membro de USF Tampa, Team 1-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G6
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 44
Ao todo: 827
