Ir para o conteúdo principal
Mid F900 Speaker Replacement
O que você precisa
  1. Mid F900 Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Speaker Replacement: passo 2, imagem 1 %32 Mid F900 Speaker Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Follow the black and red wires coming from the white back plate to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
    • Carefully use the soldering iron to desolder the wires from the motherboard.
    • Do not keep the soldering gun on the motherboard for too long or damage may occur to the device.
  4. Mid F900 Speaker Replacement: passo 4, imagem 1 %32
    • Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
    • You will need to resolder the wires from the new speaker to the motherboard.
Conclusão
Jacques Pierre
Membro desde: 09/07/16
336 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-6, Remmell Fall 2016 Membro de USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 142
