Ir para o conteúdo principal
Mid F900 Microphone Replacement
O que você precisa
  1. Mid F900 Microphone Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Microphone Replacement: passo 2, imagem 1 %32 Mid F900 Microphone Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Microphone Replacement, Motherboard: passo 3, imagem 1 %32 Mid F900 Microphone Replacement, Motherboard: passo 3, imagem 2 %32
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Microphone Replacement: passo 4, imagem 1 %32 Mid F900 Microphone Replacement: passo 4, imagem 2 %32
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Microphone Replacement: passo 5, imagem 1 %32 Mid F900 Microphone Replacement: passo 5, imagem 2 %32
    • Carefully lift and remove the motherboard from the device housing.
  6. Mid F900 Microphone Replacement, Microphone: passo 6, imagem 1 %32
    • Flip the motherboard over to bring the underside into view.
    • Find and desolder the microphone near the bottom of the motherboard and remove it.
    • Solder the new microphone in its place.
    • For soldering help, check out the How to Solder and Desolder Connections guide.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Oliva
Membro desde: 09/10/16
364 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 6-6, Remmell Fall 2016 Membro de USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 115
