Ir para o conteúdo principal
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
O que você precisa
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: passo 1, imagem 3 %32
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    Pergunte ao FixBot
    Comentar
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: passo 2, imagem 3 %32
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    Pergunte ao FixBot
    Comentar
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
    Pergunte ao FixBot
    Comentar
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, imagem 2 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: passo 4, imagem 3 %32
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
    Pergunte ao FixBot
    Comentar
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: passo 5, imagem 1 %32 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: passo 5, imagem 2 %32
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 6-9, Regan Fall 2011 Membro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 1,521
