Ir para o conteúdo principal
Microtek ScanMaker 5900 New Locking Mechanism Replacement
O que você precisa
  1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: passo 1, imagem 1 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: passo 1, imagem 2 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: passo 1, imagem 3 %32
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    Pergunte ao FixBot
    Comentar
  2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: passo 2, imagem 1 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: passo 2, imagem 2 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: passo 2, imagem 3 %32
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    Pergunte ao FixBot
    Comentar
  3. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: passo 3, imagem 1 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: passo 3, imagem 2 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: passo 3, imagem 3 %32
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    Pergunte ao FixBot
    Comentar
  4. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: passo 4, imagem 1 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: passo 4, imagem 2 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: passo 4, imagem 3 %32
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
    Pergunte ao FixBot
    Comentar
  5. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: passo 5, imagem 1 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: passo 5, imagem 2 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: passo 5, imagem 3 %32
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
    Pergunte ao FixBot
    Comentar
  6. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: passo 6, imagem 1 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: passo 6, imagem 2 %32 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: passo 6, imagem 3 %32
    • Locate the locking mechanism in the front left hand corner of the device.
    • Gently push on it until it becomes loose.
    • Rotate and jiggle it until it comes out the bottom of the scanner.
    • Find a replacement locking mechanism and insert it into the scanner.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 6-9, Regan Fall 2011 Membro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 1,726
