Ir para o conteúdo principal
Microsoft Surface RT Kick-stand Replacement
O que você precisa
    1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: passo 1, imagem 1 %32 Microsoft Surface RT Kick-stand Replacement, Kick-stand: passo 1, imagem 2 %32
      • Turn the tablet over so the screen is facing down.
      • Pull up on the bottom corners to open the stand.
      • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
      • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
      Pergunte ao FixBot
      Comentar
Conclusão
13 outras pessoas executaram este guia.
Kevin Hua
Membro desde: 01/11/13
1.685 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 17-23, Forte Winter 2013 Membro de Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 Membros
Autoria de 43 guias
12Comentários do guia
Where do you get the replacement kickstand from?
Ray - Responder Compartilhar
is this compatible with surface pro 1 ?
arqueiro - Responder Compartilhar
Do you offer a replacement kickstand for the surface rt 2?
allie - Responder Compartilhar
Does this replacement kickstand come with the screws also?
Andrea Thompson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 52
Ao todo: 41,746
