Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
Before completely removing the display, disconnect the three display cables.
Unscrew all the 23 screws located on the outside panel with the T5 torx screw driver
Use the plastic opening tool to pry out the cameras
Pull the outside panel with your hands from the Surface Pro
Use the T5 torx screw driver to unscrew the 6 T5 screws located on the left and right metal panels
Use the T2 torx screw driver to unscrew the 23 T2 screws located on the left and right metal panels
Gently pull out left and right metal panels with hands
Disconnect the two speakers with tweezers
Gently pry out the speakers with spudger
Uma outra pessoa concluiu este guia.
