Introdução
Use this guide to replace the charging port in a Microsoft Surface Pro.
O que você precisa
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
Before completely removing the display, disconnect the three display cables.
【注意!!】 画面ガラスの下部の接着がデジタイザーのフレキケーブルとも接着されています。
両面接着剤の温めが甘かったり、無理に剥がそうとするとデジタイザーのフレキケーブルが切れますので丁寧に作業を行って下さい。
my surface pro 1 has 4 flat flexi-cables connected.
I don’t know how to put back the narrow flexi cable. It is too thin and without a pulling tape?
Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
5 outras pessoas executaram este guia.
4 comentários
Where do you get a replacement charging port at?
Be patient. I spent at least 10 to 15 minutes warming and trying to pry up the screen with my spudgers and such. It got so hot I would use one spudger to hold the Surface from the opposite side while pried with the other spudger from the other side. I would get a little lip up and slide and when I felt resistance then I would heat more and make my way around the screen. I continued that many times until I was able to use the suction cup to pull it up.
Dan - Responder
