Ir para o conteúdo principal
Microsoft Surface Pro 7 Kickstand Replacement
O que você precisa
  1. Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: passo 1, imagem 1 %32 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: passo 1, imagem 2 %32 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: passo 1, imagem 3 %32
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: passo 2, imagem 1 %32 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: passo 2, imagem 2 %32
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: passo 3, imagem 1 %32 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: passo 3, imagem 2 %32 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: passo 3, imagem 3 %32
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: passo 4, imagem 1 %32 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: passo 4, imagem 2 %32 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: passo 4, imagem 3 %32
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
Conclusão
Uma outra pessoa concluiu este guia.
Sam Omiotek
Membro desde: 02/25/19
73.429 Reputação
Autoria de 288 guias
2 comentários
One of the hinges broke on my Surface Pro 6.
1. I removed the broken hinge, closed the kickstand and duct taped the seam.
2. I opened the kickstand wide and duct taped the seam.
The single hinge and duct tape seem to be working!
"Spare the duct tape, spoil the job." - Red Green
P Best - Responder
What are the parts used for this fix?
Andrea Shaw - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 51
Últimos 30 dias: 211
Duração total: 6,574
