Ir para o conteúdo principal
Microsoft Surface Pro 6 Kickstand Replacement
O que você precisa
  1. Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: passo 1, imagem 1 %32 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: passo 1, imagem 2 %32 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: passo 1, imagem 3 %32
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: passo 2, imagem 1 %32 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: passo 2, imagem 2 %32
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: passo 3, imagem 1 %32 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: passo 3, imagem 2 %32 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: passo 3, imagem 3 %32
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: passo 4, imagem 1 %32 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: passo 4, imagem 2 %32 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: passo 4, imagem 3 %32
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
Conclusão
7 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
29.252 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
7 comentários
Any way to replace the hinges themself?
Only-Wonder - Responder
Also trying to find this out.
Bobby Stephenson -
Thank you so much. I use the Surface 6 in portrait mode to read and use the kickstand as a grip/hand rest to prevent wrist strain. This meant the screws came loose constantly and I had to try and tighten them using my fingertip; not ideal. With the newly purchased Manta kit, and this guide, they are properly tightened again for the first time in over a year.
Chris Goodluck - Responder
If you find that that the kickstand screws are still coming loose, I suggest applying a dab of blue Loctite (or nail polish if in a pinch) to the screws to help them hold in place.
Arthur Shi -
The hinge mechanism has come completely loose so that the stand will not glide back into position. I thought it was the adhesive pads keeping it in place. Reading the instructions above, I now see that these pads can be put back into position. There is a whole Youtube showing the headaches of this kickstand hinge situation. The best bet is to buy a cover with a kickstand attached.
zsugahill - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 17
Últimos 30 dias: 93
Duração total: 22,509
