Ir para o conteúdo principal
Microsoft Surface Pro 5 Camera Tie Bar Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Disconnect the display board: passo 1, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Disconnect the display board: passo 1, imagem 2 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Disconnect the display board: passo 1, imagem 3 %32
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 2, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 2, imagem 2 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the display board: passo 3, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the display board: passo 3, imagem 2 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the display board: passo 3, imagem 3 %32
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 4, imagem 1 %32
    Tesa 61395 Tape
    $5.99
    Comprar
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 5, imagem 1 %32
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink shield: passo 6, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink shield: passo 6, imagem 2 %32
    Comprar
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  7. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 7, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 7, imagem 2 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 7, imagem 3 %32
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  8. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 8, imagem 1 %32
    • Remove the heat sink shield.
  9. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink: passo 9, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink: passo 9, imagem 2 %32
    • Remove the ten Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
  10. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 10, imagem 1 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 10, imagem 2 %32 Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 10, imagem 3 %32
  11. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Camera Tie Bar: passo 11, imagem 1 %32
    • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
  12. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 12, imagem 1 %32
    • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
  13. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 13, imagem 1 %32
    Comprar
    • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
  14. Microsoft Surface Pro 5 Camera Tie Bar Replacement: passo 14, imagem 1 %32
    • Lift the camera tie bar off of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Paul Manzer
Membro desde: 10/02/17
752 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G3, Livingston Fall 2017 Membro de Cal Poly, Team S15-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G3
Membros da 3
Autoria de 17 guias
2 comentários
Do you really need to remove the heat sink shield and the heat sink to disconnect the tie bar small ribbon cable ?
Tamanaco Francisquez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 928
