Ir para o conteúdo principal
Microsoft Surface Pro 11 SSD Replacement
O que você precisa
  1. Microsoft Surface Pro 11 SSD Replacement, Before you begin: passo 1, imagem 1 %32 Microsoft Surface Pro 11 SSD Replacement, Before you begin: passo 1, imagem 2 %32 Microsoft Surface Pro 11 SSD Replacement, Before you begin: passo 1, imagem 3 %32
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: passo 2, imagem 1 %32 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: passo 2, imagem 2 %32 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: passo 2, imagem 3 %32
    • Lay your Surface Pro screen side down and open the kickstand to about a 90‑degree angle.
  3. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: passo 3, imagem 1 %32 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: passo 3, imagem 2 %32 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: passo 3, imagem 3 %32
    • Use your finger to firmly press down on the SSD door indent until the door pops up.
    • Remove the SSD door.
  4. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: passo 4, imagem 1 %32 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: passo 4, imagem 2 %32
    • Use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
  5. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: passo 5, imagem 1 %32 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: passo 5, imagem 2 %32 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: passo 5, imagem 3 %32
    • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
    • Use the flat end of a spudger to gently lift the notched edge of the SSD enough that you can grip the bottom corners with your fingers.
    • Use your fingers or tweezers to pull the SSD straight out of its socket and remove it.
    • During reassembly, getting the SSD fully inserted in its socket can be tricky. If you're having trouble, hold the SSD in place and use the flat end of a spudger to push on the notched edge.
Conclusão
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Spencer Day
Membro desde: 09/14/22
149.601 Reputação
Autoria de 995 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.626 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 119
Últimos 30 dias: 700
Ao todo: 3,474
