Introdução
Use this guide to remove or replace the upper case of a Microsoft Surface Laptop 3 (13.5").
The upper case contains the keyboard and touchpad.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
O que você precisa
Flip the laptop over and place it on your work surface, feet facing up.
Each foot has a hidden indent that will simplify removal.
To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
Push the spudger underneath the foot and pry up to release it.
Repeat to remove the second rear foot.
Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
Repeat to remove the second front foot.
Note that the front and rear feet are different.
Note that the front feet are directional and only clip in one way.
Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
Grip the top edge of upper case above the keyboard and lift straight up to release it.
Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
Remove the ribbon cable from the motherboard.
Remove the upper case.
Set the upper case onto a clean surface, keyboard-side down.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
3 outras pessoas executaram este guia.
5 comentários
The upper case is secured with four 3.0 mm-long Torx T5 screws located under each foot: Microsoft Surface Laptop 3 13.5" Upper Case Replacement
English below
Bonjour,
Je ne trouve pas de pièces détachées pour remplacer le clavier de mon surface laptop 3 qui ne march eplus correctement. Ou puis-je en en trouver ?
merci pour votre réponse
Hello,
I do not find any spare part to change the keyboard of my surface laptop 3 which does not work well. Where can I find it?
thank you for the answer.
Bonjour,
Je ne trouve pas de pièces détachées pour remplacer le clavier de mon surface laptop 3 de QWERTY en AZERTY. Ou puis-je en en trouver ?
Hello,
I do not find any spare part to change the keyboard of my surface laptop 3 from QWERTY to AZERTY. Where can I find it?
