Ir para o conteúdo principal
Microsoft Surface Headphones Motherboard Replacement
O que você precisa
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Microsoft Surface Headphones Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: passo 3, imagem 1 %32
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: passo 4, imagem 1 %32
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: passo 5, imagem 1 %32
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: passo 6, imagem 1 %32
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 970
