Introdução
This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop.
The battery guide itself can also prove to be very difficult. The battery is secured to the laptop with very strong adhesive, which makes it troublesome to remove. It is recommended that you use isopropyl alcohol to help get the glue off the laptop.
A majority of the issues that are found with the Microsoft Surface Book 2 15" can be solved through software solutions. Make sure to review troubleshooting page and try the solutions listed there before making any repairs to the device.
O que você precisa
Open the laptop, then orient it so the touchpad is on your left.
Starting at the hinge, count six holes up on the tablet portion of the laptop.
Use an iOpener or a heat gun (on low heat) to carefully heat the back side of the tablet to help soften the battery adhesive.
Use prying tools such as a guitar pick, plastic card, or a nylon spudger to help sever the adhesive, and gently lift the battery free.
3 outras pessoas executaram este guia.
3 comentários
The first paragraph of this Surface Book 2 battery replacement guide is:
"This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop."
The first paragraph of the motherboard replacement guide is:
This guide is used to explain how to open up the tablet portion of the Microsoft Surface Book 2 15 and gain access to the motherboard. The motherboard of the Microsoft Surface Book 2 15 has a majority of the cables for parts that can be replaced on it.
Does this mean that I have to go through all the replacement motherboard steps and replace the motherboard before replacing the battery?
You won't need to replace the mobo, but yes, it looks like you'll have to remove it. This guide is pretty confusing right now IMO
I also find it rather confusing.
Thanks darth mango.
