Ir para o conteúdo principal
Microsoft Surface 2 Volume Control Replacement
O que você precisa
    1. Microsoft Surface 2 Volume Control Replacement, Screen: passo 1, imagem 1 %32 Microsoft Surface 2 Volume Control Replacement, Screen: passo 1, imagem 2 %32 Microsoft Surface 2 Volume Control Replacement, Screen: passo 1, imagem 3 %32
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface 2 Volume Control Replacement: passo 2, imagem 1 %32 Microsoft Surface 2 Volume Control Replacement: passo 2, imagem 2 %32 Microsoft Surface 2 Volume Control Replacement: passo 2, imagem 3 %32
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Microsoft Surface 2 Volume Control Replacement, Volume Control: passo 3, imagem 1 %32 Microsoft Surface 2 Volume Control Replacement, Volume Control: passo 3, imagem 2 %32
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface 2 Volume Control Replacement: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Gently peel off the yellow plastic tape using a pair of tweezers.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Surface 2 Volume Control Replacement: passo 5, imagem 1 %32
      • Remove the two 1.70 mm T3 screws from the volume control switch.
      Pergunte ao FixBot
      Comentar
    4. Microsoft Surface 2 Volume Control Replacement: passo 6, imagem 1 %32
      • Use a spudger to lift up the retaining flap on the volume control cable ZIF connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      Pergunte ao FixBot
      Comentar
    5. Microsoft Surface 2 Volume Control Replacement: passo 7, imagem 1 %32
      • Now that the volume control switch is loose, pull it gently away from the motherboard.
      • No force is needed to plug in or remove the ribbon cable.
      Pergunte ao FixBot
      Comentar
Conclusão
oluchianya
Membro desde: 02/04/16
157 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-1, Wollert Spring 2016 Membro de USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 Membros
Autoria de 40 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 64
Ao todo: 2,052
