Ir para o conteúdo principal
Microsoft Surface 2 I/O Cable Replacement
O que você precisa
    1. Microsoft Surface 2  I/O Cable Replacement, Screen: passo 1, imagem 1 %32 Microsoft Surface 2  I/O Cable Replacement, Screen: passo 1, imagem 2 %32 Microsoft Surface 2  I/O Cable Replacement, Screen: passo 1, imagem 3 %32
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface 2  I/O Cable Replacement: passo 2, imagem 1 %32 Microsoft Surface 2  I/O Cable Replacement: passo 2, imagem 2 %32 Microsoft Surface 2  I/O Cable Replacement: passo 2, imagem 3 %32
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: passo 3, imagem 1 %32 Microsoft Surface 2  I/O Cable Replacement, I/O Cable: passo 3, imagem 2 %32
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface 2  I/O Cable Replacement: passo 4, imagem 1 %32 Microsoft Surface 2  I/O Cable Replacement: passo 4, imagem 2 %32
      • Remove the two 2.19 mm T3 screws that hold down the SD card ribbon cable.
      • Remove the two 3.27 mm T3 screws holding down the charging port.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Surface 2  I/O Cable Replacement: passo 5, imagem 1 %32 Microsoft Surface 2  I/O Cable Replacement: passo 5, imagem 2 %32 Microsoft Surface 2  I/O Cable Replacement: passo 5, imagem 3 %32
      • Use a spudger to pry up the retaining plate at the end of the ribbon cable.
      • The retaining chip may be glued to the motherboard.
      • Use the spudger to flip up the small retaining flap on the cable's zero insertion force connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      • Remove the ribbon cable from its port.
      • No force is needed to plug in or remove the ribbon cable.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 3-1, Wollert Spring 2016 Membro de USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 Membros
Autoria de 20 guias
2Comentários do guia
I want to replace the battery of Microsoft Surface 2, which steps I have to follow to replace it?
Piero Sabino - Responder Compartilhar
Cosa devo utilizzare per attaccare il cavo del display sotto al fermaglio di distanza, colla o nastro biadesivo?
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 54
Ao todo: 5,300
