Ir para o conteúdo principal
Microsoft Kinect Camera Replacement
O que você precisa
  1. Microsoft Kinect Camera Replacement, Case: passo 1, imagem 1 %32 Microsoft Kinect Camera Replacement, Case: passo 1, imagem 2 %32 Microsoft Kinect Camera Replacement, Case: passo 1, imagem 3 %32
    • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
    • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
    • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
    • Do not overheat as it may cause damage to the internal components.
    Pergunte ao FixBot
    Comentar
  2. Microsoft Kinect Camera Replacement: passo 2, imagem 1 %32
    • Unscrew the six 12mm T10 Torx screws.
    Pergunte ao FixBot
    Comentar
  3. Microsoft Kinect Camera Replacement: passo 3, imagem 1 %32 Microsoft Kinect Camera Replacement: passo 3, imagem 2 %32 Microsoft Kinect Camera Replacement: passo 3, imagem 3 %32
    • Remove the top portion of the case from the rest of the body.
    • Detach the side portions of the case from the body.
    • Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
    • When unplugging the fan, be sure to pull from the white connector at the end of the wire to avoid breaking it.
    Pergunte ao FixBot
    Comentar
  4. Microsoft Kinect Camera Replacement: passo 4, imagem 1 %32
    • Remove the bottom portion of the case by sliding it out from under the body.
    • The bottom of the case may be difficult to remove if there is any residual adhesive. If the residual adhesive prevents you from removing the case, apply gentle heat and wiggle the case out.
    Pergunte ao FixBot
    Comentar
  5. Microsoft Kinect Camera Replacement: passo 5, imagem 1 %32 Microsoft Kinect Camera Replacement: passo 5, imagem 2 %32
    • Remove the four 7mm T10 Torx screws (two on each side of the metal body).
    Pergunte ao FixBot
    Comentar
  6. Microsoft Kinect Camera Replacement: passo 6, imagem 1 %32 Microsoft Kinect Camera Replacement: passo 6, imagem 2 %32
    • Remove the front portion of the case containing the lens coverings for the cameras.
    • The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
    Pergunte ao FixBot
    Comentar
  7. Microsoft Kinect Camera Replacement, Microphone Panel: passo 7, imagem 1 %32
    • Unplug the microphone from motherboard.
    Pergunte ao FixBot
    Comentar
  8. Microsoft Kinect Camera Replacement: passo 8, imagem 1 %32
    • Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
    • Pull the cable out carefully to avoid damage.
    Pergunte ao FixBot
    Comentar
  9. Microsoft Kinect Camera Replacement, Motherboard: passo 9, imagem 1 %32
    • Unscrew the seven 6.5mm T10 Torx screws.
    Pergunte ao FixBot
    Comentar
  10. Microsoft Kinect Camera Replacement: passo 10, imagem 1 %32
    • Disconnect the bridge connecting the first and second layer of the motherboard.
    • Pull the first layer of the motherboard off.
    Pergunte ao FixBot
    Comentar
  11. Microsoft Kinect Camera Replacement: passo 11, imagem 1 %32
    • Unplug the LED cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Microsoft Kinect Camera Replacement: passo 12, imagem 1 %32
    • Unscrew the three 16.5mm screws using the 5mm Nut Driver.
    • Unscrew the one 6.5mm T10 Torx screw.
    Pergunte ao FixBot
    Comentar
  13. Microsoft Kinect Camera Replacement: passo 13, imagem 1 %32 Microsoft Kinect Camera Replacement: passo 13, imagem 2 %32
    • Remove the three ribbon cables.
    • Disconnect the left most camera from the motherboard.
    Pergunte ao FixBot
    Comentar
  14. Microsoft Kinect Camera Replacement, LED: passo 14, imagem 1 %32
    • Gently pull the LED out of the front of the metal casing. It should slide out easily.
    Pergunte ao FixBot
    Comentar
  15. Microsoft Kinect Camera Replacement, Camera: passo 15, imagem 1 %32
    • Unscrew the four 7mm T10 Torx screws from the plastic body.
    Pergunte ao FixBot
    Comentar
  16. Microsoft Kinect Camera Replacement: passo 16, imagem 1 %32
    • Remove the gold metal cylindrical piece from the metal body on the left side of the Kinect.
    Pergunte ao FixBot
    Comentar
  17. Microsoft Kinect Camera Replacement: passo 17, imagem 1 %32
    • Carefully remove the top body portion of the Kinect from the stand by guiding the cable through the hole on the underside of the body, then lifting the body off of the plastic stand.
    Pergunte ao FixBot
    Comentar
  18. Microsoft Kinect Camera Replacement: passo 18, imagem 1 %32
    • Unscrew the nine 7mm T6 Torx screws from the metal body. These hold the cameras in place.
    Pergunte ao FixBot
    Comentar
  19. Microsoft Kinect Camera Replacement: passo 19, imagem 1 %32
    • Remove the plastic body from the metal body by sliding it off of the metal cylinders.
    Pergunte ao FixBot
    Comentar
  20. Microsoft Kinect Camera Replacement: passo 20, imagem 1 %32
    • Remove the two cameras on the left (which are connected) by pulling their ribbon cables through their respective slots.
    Pergunte ao FixBot
    Comentar
  21. Microsoft Kinect Camera Replacement: passo 21, imagem 1 %32
    • Remove the right camera from the metal body by sliding the cable through the hole it lies in.
    • The cable can be difficult to slide through the hole because of the large rubber parts attached to it. To manage this, simply squeeze the rubber parts to fit through the hole.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Sumi Kime
Membro desde: 04/22/15
234 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-7, Amido Spring 2015 Membro de Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 67
Ao todo: 3,589
