Ir para o conteúdo principal
Microsoft Band Wrist Clasp Replacement
O que você precisa
    1. Microsoft Band Wrist Clasp Replacement, Wrist Clasp: passo 1, imagem 1 %32
      • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Band Wrist Clasp Replacement: passo 2, imagem 1 %32
      • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Band Wrist Clasp Replacement: passo 3, imagem 1 %32
      • Pull the two securing pins out of the rubberized part of the band.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Chad Steese
Membro desde: 02/02/15
259 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-34, Amido Winter 2015 Membro de Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Membros
Autoria de 6 guias
3Comentários do guia
where can I purchase the replacement part
jeepgirlutah - Responder Compartilhar
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
dopplerdefekt - Responder Compartilhar
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
Xavier Ribas Roig - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 30
Ao todo: 5,491
