Ir para o conteúdo principal
Microsoft Band Battery Replacement
O que você precisa
    1. Microsoft Band Battery Replacement, Battery: passo 1, imagem 1 %32
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Band Battery Replacement: passo 2, imagem 1 %32
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Band Battery Replacement: passo 3, imagem 1 %32
      • Gently pry up one edge of the battery with the plastic spudger.
      Pergunte ao FixBot
      Comentar
    4. Microsoft Band Battery Replacement: passo 4, imagem 1 %32
      • Remove battery from its compartment with your fingers.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 17-34, Amido Winter 2015 Membro de Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Membros
Autoria de 18 guias
5Comentários do guia
where can i buy the battery?
chirac - Responder Compartilhar
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - Responder Compartilhar
Will this be dangerous?
Rei zzstu Shiozawa - Responder Compartilhar
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Responder Compartilhar
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Ao todo: 12,603
