Ir para o conteúdo principal
MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Determine the unloader assembly: passo 1, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Determine the unloader assembly: passo 1, imagem 2 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Determine the unloader assembly: passo 1, imagem 3 %32
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement: passo 2, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement: passo 2, imagem 2 %32
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the hose clamp: passo 3, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the hose clamp: passo 3, imagem 2 %32
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Disconnect the return hose: passo 4, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Disconnect the return hose: passo 4, imagem 2 %32
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Position the support block: passo 5, imagem 1 %32
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Re-position the return elbow: passo 6, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Re-position the return elbow: passo 6, imagem 2 %32
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the filter: passo 7, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the filter: passo 7, imagem 2 %32
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Remove the filter: passo 8, imagem 1 %32
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the input elbow: passo 9, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the input elbow: passo 9, imagem 2 %32
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Remove the input elbow: passo 10, imagem 1 %32
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the output assembly: passo 11, imagem 1 %32 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the output assembly: passo 11, imagem 2 %32
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Remove the output assembly: passo 12, imagem 1 %32
    • Remove the output assembly.
Conclusão
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
Arthur Shi
Membro desde: 01/03/18
283.341 Reputação
Autoria de 587 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.633 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 24
