Introdução
Use this guide to remove or replace the belt guard in a Mi-T-M Air Compressor AM1-PH65-08HD 2012.
This is a prerequisite-only guide. This guide is part of another procedure and is not meant to be used alone.
O que você precisa
Use a 10 mm socket to remove the bolt securing the belt guard.
Tilt the belt guard away from the device and lift it out to remove it.
Quase terminado!
Conclusão
