Ir para o conteúdo principal
MerchSource the Black Series Boat Racer Battery Cable Replacement
O que você precisa
  1. MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: passo 1, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: passo 1, imagem 2 %32
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 2, imagem 1 %32
    • Slide the battery cover off.
  3. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 3, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 3, imagem 2 %32
    • Remove both AA-batteries.
  4. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 5, imagem 1 %32 MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 5, imagem 2 %32 MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 5, imagem 3 %32
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 6, imagem 1 %32
    • Solder the wire to reconnect it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 216
