Ir para o conteúdo principal
Merch Source Projector Entertainment II Light Bulb Replacement
O que você precisa
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: passo 1, imagem 1 %32 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: passo 1, imagem 2 %32
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Pergunte ao FixBot
      Comentar
    2. Merch Source Projector Entertainment II Light Bulb Replacement: passo 2, imagem 1 %32
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Pergunte ao FixBot
      Comentar
    3. Merch Source Projector Entertainment II Light Bulb Replacement: passo 3, imagem 1 %32 Merch Source Projector Entertainment II Light Bulb Replacement: passo 3, imagem 2 %32
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Pergunte ao FixBot
      Comentar
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: passo 4, imagem 1 %32 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: passo 4, imagem 2 %32 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: passo 4, imagem 3 %32
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
      Pergunte ao FixBot
      Comentar
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: passo 5, imagem 1 %32 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: passo 5, imagem 2 %32
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Stephanie
Membro desde: 01/08/15
282 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-3, Maness Winter 2015 Membro de Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Membros
Autoria de 8 guias
1Comentário do guia
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 2,654
