Introdução
Is your projector overheating? Is it powering down at random times? Use this guide to replace the malfunctioning fan. Replacing the fan requires a fine tip soldering iron and should be done by those with solder experience.
O que você precisa
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Uma outra pessoa concluiu este guia.
