Ir para o conteúdo principal
Memorex CD Alarm Clock Radio Antenna Replacement
O que você precisa
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: passo 1, imagem 1 %32 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: passo 1, imagem 2 %32 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: passo 1, imagem 3 %32
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: passo 2, imagem 1 %32 Memorex CD Alarm Clock Radio Antenna Replacement: passo 2, imagem 2 %32 Memorex CD Alarm Clock Radio Antenna Replacement: passo 2, imagem 3 %32
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: passo 3, imagem 1 %32
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 763
