Ir para o conteúdo principal
Maze Speed SSB-508 Power and Volume Button Replacement
O que você precisa
  1. Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: passo 1, imagem 1 %32 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: passo 1, imagem 2 %32 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: passo 1, imagem 3 %32
    • Remove the back cover by gently prying open the bottom left corner of the case with the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  2. Maze Speed SSB-508 Power and Volume Button Replacement: passo 2, imagem 1 %32 Maze Speed SSB-508 Power and Volume Button Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • There are three areas holding the power and volume buttons in place. Gently pull the bottom of the power button with a pair of fine-tip tweezers to release the lower half.
    Pergunte ao FixBot
    Comentar
  3. Maze Speed SSB-508 Power and Volume Button Replacement: passo 3, imagem 1 %32 Maze Speed SSB-508 Power and Volume Button Replacement: passo 3, imagem 2 %32 Maze Speed SSB-508 Power and Volume Button Replacement: passo 3, imagem 3 %32
    • Carefully remove the top section of the button with the fine-tip tweezers . This should free the button completely.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 618
