Ir para o conteúdo principal
Mayflash Arcade Stick F300 USB Cable Replacement
O que você precisa
  1. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: passo 1, imagem 1 %32 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: passo 1, imagem 2 %32 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: passo 1, imagem 3 %32
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    Pergunte ao FixBot
    Comentar
  2. Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: passo 2, imagem 1 %32 Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: passo 2, imagem 2 %32
    • Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Mayflash Arcade Stick F300 USB Cable Replacement: passo 3, imagem 1 %32 Mayflash Arcade Stick F300 USB Cable Replacement: passo 3, imagem 2 %32 Mayflash Arcade Stick F300 USB Cable Replacement: passo 3, imagem 3 %32
    • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
    • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
    • Use a metal spudger to gently remove the softened glue.
    • Remove the cable from the socket
    Pergunte ao FixBot
    Comentar
  4. Mayflash Arcade Stick F300 USB Cable Replacement: passo 4, imagem 1 %32 Mayflash Arcade Stick F300 USB Cable Replacement: passo 4, imagem 2 %32 Mayflash Arcade Stick F300 USB Cable Replacement: passo 4, imagem 3 %32
    • Slide the strain relief segment of the USB cable out of the plastic outer casing.
    • Remove the cable.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jess Anderson
Membro desde: 09/04/24
342 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 38
Ao todo: 572
