Introdução
If the PCB (printed circuit board) on your Mayflash Arcade Stick F300 is causing an unstable connection to your console and needs replaced, use this guide.
The PCB plays a critical role in connecting, interpreting, and transmitting user inputs to the gaming system. If it has been exposed to excess moisture, extreme temperatures, or other issues it will cause difficulty connecting the controller or otherwise unreliable use.
O que você precisa
Flip the controller upside down so that the metal panel is facing you.
Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
Once all screws are removed, lift off the panel.
Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
Follow these instructions in reverse order to reassemble your device.
