Ir para o conteúdo principal
Master and Dynamic MW50 Right/Left Speaker Replacement
O que você precisa
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 1 %32 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 2 %32 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 3 %32
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: passo 2, imagem 1 %32
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: passo 3, imagem 1 %32
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: passo 4, imagem 1 %32
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: passo 5, imagem 1 %32
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Conclusão
Katie Dunnigan
Membro desde: 01/24/19
85 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S1-G4, White Winter 2019 Membro de Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
Membros da 4
Autoria de 12 guias
Um comentário
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 659
