Ir para o conteúdo principal
Master and Dynamic MW50 Charging Port Replacement
O que você precisa
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 1 %32 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 2 %32 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 3 %32
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: passo 2, imagem 1 %32
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: passo 3, imagem 1 %32
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: passo 4, imagem 1 %32 Master and Dynamic MW50 Charging Port Replacement, Charging Port: passo 4, imagem 2 %32
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: passo 5, imagem 1 %32
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: passo 6, imagem 1 %32
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
Conclusão
Tyler Guffey
Membro desde: 01/24/19
208 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S1-G4, White Winter 2019 Membro de Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 309
