Ir para o conteúdo principal
Master and Dynamic MW50 Battery Replacement
O que você precisa
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 1 %32 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 2 %32 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, imagem 3 %32
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: passo 2, imagem 1 %32
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: passo 3, imagem 1 %32
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: passo 4, imagem 1 %32 Master and Dynamic MW50 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: passo 5, imagem 1 %32
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: passo 6, imagem 1 %32 Master and Dynamic MW50 Battery Replacement: passo 6, imagem 2 %32
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
Conclusão
Tyler Guffey
Membro desde: 01/24/19
208 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S1-G4, White Winter 2019 Membro de Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
Membros da 4
Autoria de 12 guias
Um comentário
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 41
Duração total: 1,774
