Ir para o conteúdo principal
Martian Victory Watch Face Replacement
O que você precisa
  1. Martian Victory Watch Face Replacement, Back Plate: passo 1, imagem 1 %32 Martian Victory Watch Face Replacement, Back Plate: passo 1, imagem 2 %32
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Watch Face Replacement: passo 2, imagem 1 %32
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Watch Face Replacement, Lithium Battery: passo 3, imagem 1 %32
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Watch Face Replacement: passo 4, imagem 1 %32
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Watch Face Replacement, Motherboard: passo 5, imagem 1 %32
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Watch Face Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Watch Face Replacement: passo 7, imagem 1 %32
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Watch Face Replacement: passo 8, imagem 1 %32 Martian Victory Watch Face Replacement: passo 8, imagem 2 %32 Martian Victory Watch Face Replacement: passo 8, imagem 3 %32
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Watch Face Replacement: passo 9, imagem 1 %32 Martian Victory Watch Face Replacement: passo 9, imagem 2 %32
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
  10. Martian Victory Watch Face Replacement, LED Screen: passo 10, imagem 1 %32
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  11. Martian Victory Watch Face Replacement: passo 11, imagem 1 %32
    Comprar
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  12. Martian Victory Watch Face Replacement: passo 12, imagem 1 %32
    • Remove the screw driver holding the LED screen and Speaker in place.
  13. Martian Victory Watch Face Replacement: passo 13, imagem 1 %32
    • Insert a small flat screw driver under the speaker in order to remove it.
  14. Martian Victory Watch Face Replacement: passo 14, imagem 1 %32 Martian Victory Watch Face Replacement: passo 14, imagem 2 %32
    • Using tweezers, remove the speaker and move off to the side.
  15. Martian Victory Watch Face Replacement: passo 15, imagem 1 %32 Martian Victory Watch Face Replacement: passo 15, imagem 2 %32
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  16. Martian Victory Watch Face Replacement: passo 16, imagem 1 %32
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
  17. Martian Victory Watch Face Replacement, Watch Face: passo 17, imagem 1 %32 Martian Victory Watch Face Replacement, Watch Face: passo 17, imagem 2 %32
    Comprar
    • Grab the motherboard with tweezers and remove from watch cavity.
  18. Martian Victory Watch Face Replacement: passo 18, imagem 1 %32 Martian Victory Watch Face Replacement: passo 18, imagem 2 %32
    • Stabilize watch with the metal prove. Place tweezers around crown and pull outward, so that the crown can be removed.
  19. Martian Victory Watch Face Replacement: passo 19, imagem 1 %32
    • Insert the spudger under plastic panel cover in order to access watch face.
  20. Martian Victory Watch Face Replacement: passo 20, imagem 1 %32 Martian Victory Watch Face Replacement: passo 20, imagem 2 %32 Martian Victory Watch Face Replacement: passo 20, imagem 3 %32
    • Insert a spudger under the black watch face. Gently push up, so that it can be raised out of the watch.
    • Use tweezers or pin tool in order to remove from watch.
Conclusão
Robert Sanchez
Membro desde: 10/31/16
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-3, Baechle Fall 2016 Membro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 403
