Ir para o conteúdo principal
Martian Victory Motherboard Replacement
O que você precisa
  1. Martian Victory Motherboard  Replacement, Back Plate: passo 1, imagem 1 %32 Martian Victory Motherboard  Replacement, Back Plate: passo 1, imagem 2 %32
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Motherboard  Replacement: passo 2, imagem 1 %32
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Motherboard  Replacement, Lithium Battery: passo 3, imagem 1 %32
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Motherboard  Replacement: passo 4, imagem 1 %32
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Motherboard  Replacement, Motherboard: passo 5, imagem 1 %32
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Motherboard  Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Motherboard  Replacement: passo 7, imagem 1 %32
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Motherboard  Replacement: passo 8, imagem 1 %32 Martian Victory Motherboard  Replacement: passo 8, imagem 2 %32 Martian Victory Motherboard  Replacement: passo 8, imagem 3 %32
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Motherboard  Replacement: passo 9, imagem 1 %32 Martian Victory Motherboard  Replacement: passo 9, imagem 2 %32
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
Conclusão
Dominic Coffey
Membro desde: 10/24/16
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-3, Baechle Fall 2016 Membro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 190
